I replaced the tires on my Horse from standards to the bar treads. Repainted he wheels an installed new hub caps.
Boy, did I have a check of a time getting those wheels off! I made a Blizzard wheel puller cause I didn't want to spend $250 dollars for one. It worked very well, but you have to use intense vibration along with pulling. Or else the puller bars will bend if you try to just crank down on the forcing screw. The best way is, pull, vibrate, pull, vibrate.....
And use lubricant liberally.
