1 - 9 of 9 Posts
I will need a riding mower to mow the 1 acre lot where I am getting ready to build. For no good reason, I find myself keenly interested in purchasing an older lawn tractor. There seem to be numerous “newer” riding mowers with thrashed engines and non-working transmissions. So, perhaps a more durable mower and the nostalgia seem appealing to me. I am moderately mechanically inclined – I can do minor repairs and parts replacement as needed…short of an engine rebuild. My question is:
Are parts generally available for some/many of the late 60s or early 70s mowers (IH, Case, JD)? For stuff that may require replacements such as bearings, moving parts, etc, are they reasonable in price?
I have found an IH Cub Cadet 1250 ($450) that is said to be in good running condition. have also seen a Case 224 14hp hydo($750) that appears in good condition. I wouldn’t mind paying $400 for something in working order. The $750 seems a bit more than I would want to spend…unless it was in VERY good condition. Just my unfounded opinion/thoughts.
In short, I am not looking for a full restoration, just a fix up, tinker, paint and enjoy lawn mower. Or, would I be better off just to by a newer, used riding mower and just go mow my grass.
Thanks for any input.
Murray tractor owner
I would go with the Cub cadet 1250, What else do you plan on doing other than mow grass (snow removal, Garden, landscaping, loader, mowing, etc)??
I could concievably move some snow/ice - but in Okla...doubtful. However, we did get 14" in this winter in one day! To answer your question- most likely it would be just to mow.
Look for a Bolens. A tube frame would be perfect for you. If You give me your specific location and how far you want to drive, I can look around CL for you and see if there are any good deals.
Jason
I am in OKC. I can be out of the state in less than two hours any direction...to give you an idea. CL is where I found the older Case and Cub Cadet. Thanks.
Just Have a Little Faith!
Yes, as long as you are reasonably mechanical and have the repair manual, you will do well with either of those. Case just generally is a more expensive tractor. Just look the tractor of choice over really well. Run it and check everything. We're here for you.
I'd go with the cub cadet 1250, later if you decide to get a snow/dozer blade for it you can plow dirt and snow so it is more useful.
For that price range you could find a John Deere 140 that would have 1 to 3 spools of hydraulics, can get a new replacement deck, snowblower, and parts and accessories are still pretty available, and they are now starting to appreciate in price!
1 - 9 of 9 Posts
