I found a real steal on a tiller and a front plow for my 322 a guy had them on a 318 and I'm just curious he said he has everything to hook up and run the tiller but I want to make sure when I go to get everything. What's required?
It's the 48 mechanical tiller. Hey has the lift rod but he wasn't sure it he would be able to get the shaft out of the 318 very easily. I'm hoping he can.
The hydraulic tiller should be 30 inch or 42 inch from what I know but I could be wrong, And like Wfburton159 said, the 48 inch should be a mechanical tiller.
He may have been running that on a 317 but not a 318. That model works with the closed rear end found on 317, 316 (Kohler early model), 314, 312, but not on 316 later, 318, 322, or 332.
Many folks don't realize that JD changed the rear to the open style and those attachments that fit the closed rear machines no longer worked with the open rear end. The advantage was a true 3pt cat 0 hitch was available for the open rear machines.
I'm also getting a front blade from him also. But he has 2 available. One looks like a regular JD plow and the on the one I'm not sure it looks like a scoop with a little different Mount. Not the best picture but it's all I have at the moment.
If he had a 3xx machine there just have him show you that it mounts properly up front. The frame size of the JD 400 is different and they won't fit properly on the mount points on a 3xx machine.
The 318 he's selling with the attachments is pretty beat I'm thinking he just has a bunch of random attachments that he's trying to get rid of it all in one shot. But I told him I only want the attachments. I'm no sure they even went on the tractor.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
My Tractor Forum
