1 - 8 of 8 Posts
Hi Tractor Guys,
I have a BX24, which has about 23hp and is about 4' wide. I'm looking at buying a pulverizer, which is also known as a yard tool.
My question is ~ Can my tractor handle a 60" pulverizer or should I go with a 48"? The salesman recommended a 48". The 48" from Everything Attachments is $778 (free shipping). A local implement dealer has a new Leinbach 60" for $695 plus tax at 7% equalling $743. The Kubota dealer will sell me a Woods 48" for $1225 or the Woods 60" for $1350.
I've never used one of these and think it will work well for my needs. I can't find hardly any used pulverizers in central Indiana. The ones I have found are larger or already $600+. Any thoughts or recommendations would be appreciated. Thanks.
life is good
I would first consider the weight your tractor can pick up with the 3 pt hitch.
If I'm correct your tractor should be able to handle the 60" pulverizer.
Did the salesman give you a reason that you should go with the 48"?
On second thought the 48 would be better. This works like a boxblade and the 60" might be a bit more than you have horse power for.
He said that the width of the implement would be wider than the tractor and would make a 4' easier to manuever. I think the weight wouldn't be a problem.
life is good
Is the tractor a 4 wd?
Pulling a 5ft boxblade is a chore for some tractors of that size.
Yes, it's a 4WD with a front end loader. The 5' pulverizer weighs 507 pounds. On the advice of some MTF friends, I bought a 4' box blade. I wasn't sure if using a pulverizer would be as heavy as a full box blade.
I bought a used 4' Gill and it works great. I have to have it in 4WD.
I got a great deal on the pulverizer... Craig's List can be really good.
I just used a Frontier 4' pulverizer with my 2305 this past spring,
preping the ground for new grass.
I would not want to go any bigger. There were times, it made the
2305 grunt. 2305 is 24hp.
Greg
1 - 8 of 8 Posts
