Which tractor will pull the most dead weight? All with turf tires, no weights on clay
1 - 19 of 19 Posts
Deere 330 Killer
no weights, hook level with the axle, no special tires. just pure dead weight on hard packed clay
Re: poll test
that's all the choices or that's what you have access to? :)
Deere 330 Killer
Re: poll test
all the choices, the ss16 is mine, the rest is my competition
Re: poll test
I know nothing about pulling, but under those conditions would a hydro be the best since you could "ease" the throttle and try not to spin? I dunno???
Deere 330 Killer
Re: poll test
last year it came down to the 107 and a bolens 1050, so its anybody's guess
Re: poll test
is the bolens a hydro? Funny a 10HP hydro would be in the finals.... might be all in the drivers touch.
Deere 330 Killer
Re: poll test
the bolens is geared. i think this year it will come down to my ss16 and the 582
Re: poll test
what 582 is it? kohler or briggs? Kohler hopefully....
Deere 330 Killer
Discussion Starter · #9 ·
Re: poll test
kohler i think
its white and yellow and says 582 hydro on the hood. i dunno that much about it
Re: poll test
ya, the 582 special had the briggs. How much weight are you pulling? starting at XXX and moving up?
Deere 330 Killer
Discussion Starter · #11 ·
Re: poll test
ya its a water tank on a pallet.. we need to pull it 3 feet to be a good pull.. whoever pulls the most wins
that's cool... make a video and put it on your youtube!!
Deere 330 Killer
Discussion Starter · #13 ·
will do! the pull is saturday morning
Mine, Didn't see the Craftsman as a selection. Turf tires, no weights, on ??? crushed rock drive, close enough to clay. Beat my other mower with ags. :trink40: actually, i win on on either :thThumbsU http://www.youtube.com/watch?v=kd-ucxYlzeU
i'd watch for the wards. alot of wieght in the back to start with. if, its a variable speed hydraulic lift. i bet ther's a hundred+ extra right over the drive axle.
That just shows what makes the most difference. Weight usually wins, all the machine needs to do is keep the wheel turning, the rest is up to how much traction over the rear wheels.
I don't run tractor pulls, but I found out a long time ago that moving the axle rearward and adding weight over the back wheels or in the tires lets me tow triaxle construction trailers around the yard and move just about any boat I wish with basically a junk Dynamark tractor. It out pulls my large frame Bolens and both John Deere 112 tractors. It's got the least engine torque, least overall weight, but its tendency to lift the front wheels and transfer all it's weight and my weight to the rear wheels lets it get some pretty large loads moving even with small wheels.
Simplicity Benn
how much do the drivers weigh?:hide:
Im pulling a bolens 1053 right now, second low with ags in 850, 950, and 1050 class with a wisconsin tra10d. On the clay track im in the top three every time. 12 inch hitch hieght and brought out to the outer edges of the rear tires.
1 - 19 of 19 Posts
