318 deck shut down last night mid-mow, and battery light came on. Pto light remained on.
Shut it down and tested per the shop manual, good power at the pto wire. Pulled the coil and it read at 0 ohms initially, then climbed to 1-1.2 ohms. The coil wiring had started to work loose and rub against the clutch.
Was able to re seat the magnet and finish the job, but the coil did not re engage the clutch when hot at the end of the mow.
Here's hoping my spare engine has a good PTO coil!
