1 - 20 of 36 Posts
In 1971 bolens came out with the 1886 Husky tractor. The replacement for the smaller 1477 it came with the new Kohler opposed twin to up the hp from 14 to 18 but is still had the trusty Eaton 12 for a rear end.
Engine numbers by year and production run.
1971 1886-01 K482s-35113B
1972 1886-02 K482s-35113B
1972 1886-03 K482s-35113B
1972 1886-04 K482s-35113B
1972 1886s-05 k482s-35208B
1973 1886s-06 k482s-35208B
The 1886 pictured is a 1886-04.
Discussion Starter #2
1886-01
The 1886-01 the production run of the 1886 was built in 1971 and only for that year. It was later replaced by the 1886-02 in 1972.
Here are some ways to tell it’s an 1886-01.
1. There is no cut out for the oil filter.
2. The 1886-01 is the only production run with the pull choke and throttle.
3. The PTO lever is a cast round piece you push down to engage.
4. The 1886-01 seats have a leaf spring for cushion.
5. The 1886-01 has the Eaton 12 for its rear end.
1886-02
In 1972 Bolens introduced the 1886-02 the replacement for the 1886-01.
Not much changed in-between production run other than just two things.
Here are some ways to tell it’s an 1886-02.
1. The cut out for the oil filter was added.
2. The pull choke and throttle was changed the up and down kind.
4. The 1886-02 seats have a leaf spring for cushion.
5. The 1886-02 has the Eaton 12 for its rear end.
1886-03
Some time in 1972 the 1886-02 was replaced by the 1886-03.
Here are some ways to tell it’s an 1886-03.
1. The PTO lever was changed to a flat plate style that you pull up to engage.
2. It has the up and down choke and throttle.
3. It has the cut out for the oil filter.
4. The 1886-03 seats have a leaf spring for cushion.
5. The 1886-03 has the Eaton 12 for its rear end.
1886-04
The 1886-04 is the last production run of the 1886 with the Eaton 12 as the rear end.
Here are some ways to tell it’s an 1886-04.
1. The PTO lever is the flat plate style that you pull up to engage.
4. The seat is the kind you have to put on by sliding the tabs in to 2 of 6 slots on the fender.
5. The 1886-04 has the Eaton 12 for its rear end.
1886s-05 HT18
The last 1886 production run built in 1972, and the first to replace the Eaton with the new Sundstrand 15 hydro. The 1886s-05 stayed with the off white and brown for the paint scheme.
Here are some ways to tell it’s a 1886s-05.
5. Bolens added an oil pressure gage to the dash tower above the hydraulic levers.
6. Bolens added a light to the dash tower to tell you the hydro was to hot. It’s located to the left of the oil pressure gage.
7. Bolens replace the Eaton 12 with the new Sundstrand 15 hydro.
1886s-06 HT18
The last of the 1886’s the 1886s-06 was the only production run built in 1973. The 1886s-06 is the only 1886 the have the black and white paint job. The 1886s-06 was also called the HT18 like the 1886s-05. Not much changed between the 1886s-05 and 1886s-06 other than the switch from the white and brown to the black and white paint.
Here are some ways to tell it’s a 1886s-06.
5. The 1886s-06 had the oil pressure gage on the dash tower above the hydraulic levers.
6. The 1886s-06 had a light on the dash tower to tell you the hydro was to hot. It’s located to the left of the oil pressure gage.
7. The 1886s-06 had the Sundstrand 15 hydro.
8. The 1886s-06 changed to the black and white paint job.
Discussion Starter #8
Now it would be cool if an Admin could make this a sticky.
5000 posts and climbing
Great job Jerome,this will be very helpful.
Jerome,
I just thought of one difference you forgot to mention,when the brake pedal location was changed.Maybe you can add that.
Discussion Starter #15
The brake pedal location is the same on all the 1886s and the rest of the large frames. The brake pedal is located next to the hydro control pedal. It would also be on the right side if you were sitting on the tractor.
Same side yes,but the later ones I'm sure had the pedal 2 or 3 inches to the rear,like on the HT-20.
With this information it makes my parts tractor a 03, Because of the flat PTO handle.
I LOVE Garden Tractors!!!
Ok so which is better? The Eaton 12 or The Sunstrand 15? I have heard the Eaton, but didn't the Cub hydros use a Sunstrand unit? Tough as nails as well?
Great information, now if I could just find one near me at a reasonable price. :praying:
Bolens 1886-01
:thanku: :thanku: :thanku: What great info especially for someone who owns one thank you Jerome.
1 - 20 of 36 Posts
