ive been working on this thing alot lately but cant keep it running. I put a different carb on it. It has the main adjustment and low speed adjustment. I can get it started with starting fluid but it will die out after 5 seconds. If i press the primer it will run a little bit longer but die out again. even if you keep pressing the primer it will still die out. Anyone have an idea with this? thanks alot.
