first , Thanks for the add to the forum
Second, just replaced the forward/reverse shaft on my IH 2400 A, I unbolted the cover for the Hydraulic housing ( top Plate) as I was working by myself I did not take it off, I lifted it off the dowel pins and slid it back far enough to access the Forward/reverse shaft that I was replacing, when done I slid the top plate back in place on the dowels, and bolted it down ,Here is my problem, my 3 point hitch lift only moves up about 4 inches, It worked without a problem before, What did I do ??? how can I fix this??? For those not familiar it is same as IH 454
