I have a Ariens LT12 model #963006 that's not taking grease in though the zerk fitting on the right hand side of the rear axle , as you face the back of the tractor. I have removed the zerk and it allows grease to pass through fine but when mounted to the axle will not pass any grease no matter how much force I apply to the standard size lever action grease gun ,the left side axle fitting as well as the remaining fittings on the front axle all work properly and the grease passes through them .This is a one owner machine, the axle has never been serviced .
The question's are how this one passage is blocked internally ( Does any one know how the bearings are installed in these trans-axles)
What my options are to correct it , as in
I can correct it myself ? Or does this need a dealers mechanic?
Thank You for reading this and look forward to reading the answers .
