Dunkelstar,Just be very careful when installing it. I ran into problems with the PTO hydraulic circuit leaking due to the PTO seals on the rear cover becoming deformed. Took 3 trys to get it right and maintain the PTO pressure above 220psi. The rear PTO cover and the blank cover differ on how they seat the oval PTO seal. The rear PTO cover doesn't have tabs on the inside that maintain the shape of the seal. A slight design flaw IMO.
PM me if you end of getting the rear PTO and I'll go through how I solved this . . .![]()
You are correct, there were two model year rear PTOs for the 4X5. The PTO hardware is exactly the same, the only difference is the PTO wiring harness that came with it. Early and late model 4x5's differ in the existing pre-wired harness installed at the factory that the PTO harness plugs into and the PTO module under the dash. I used an early rear PTO on my 425 and had to get the correct PTO wire harness and PTO module. Wasn't a problem, just took a bit of research.Seems like I read that there are two models for the 425-44-455 units, one for the early years and then a different model for the later years...just something to keep in mind when purchasing.
No problem Tim. Glad it worked out! I'll cross-post the solution in a more detailed thread tonight, and place a link to it here as well.Dunkelstar,
Point on! The hyraulic pressure on my PTO started out strong but would fade to almost nothing once the machine reached operating temperature rendering my PTO worthless in 10-15 minutes. Your suggestion for keeping the oval seal in the correct shape solved the problem. It's great having a strong PTO again! Thanks a bunch
Tim
PS I have taken the rear PTO cover off at least 6 times and replaced all the PTO and brake seals at least once trying to resolve this problem. A replacement rearend was my next step....all for a $2 fix! Hopefully this thread will get archived to save someone else a lot of grief and/or money.
Dunkelstar,You are correct, there were two model year rear PTOs for the 4X5. The PTO hardware is exactly the same, the only difference is the PTO wiring harness that came with it. Early and late model 4x5's differ in the existing pre-wired harness installed at the factory that the PTO harness plugs into and the PTO module under the dash. I used an early rear PTO on my 425 and had to get the correct PTO wire harness and PTO module. Wasn't a problem, just took a bit of research..
