John Deere 2002 Diesel Gator 6x4 18 HPO Yanmar
New Primary & Secondary AF, new fuel filter, oil filter and 5W30 Synthetic.
In the process of doing my gator's initial service as new owner, replacing a lift pump, a starter drawing 60+ amps before it broke, I found the PO had bypassed the Radiator B3 Fan temp switch and my fan runs 100%.
For now, its fine. While troubleshooting after the above replaced, replaced my glow plug module and since the starter K1 was cheap, it too.
So my fan runs all the time. It was a Florida Gator, so it may as well run all the time, and this summer its fine in VA, but want to look into this before winter.
So, a seat -of - the pants question for other Gator owners: how often does your fan switch "on" for cooling?
Wayne
FYI - other than the radiator temp switch, I have replaced worn and missing item, and its OEM. And while the VA temps are 90+ this is no issue. Looking ahead to winter...
Wayne
