Last winter when I was snowblowing, traction was terrible on my 111. I had chains and 2 cinder blocks but that sure wasn't enough. Any cheap ideas or pictures of your weight setup would be greatly appreciated!
If you change your own oil, use the 5 qt jugs. Fill the jugs with concrete and you have some 'poor mans' suitcase weights. With concrete alone they'll be about 25 lbs a piece.Last winter when I was snowblowing, traction was terrible on my 111. I had chains and 2 cinder blocks but that sure wasn't enough. Any cheap ideas or pictures of your weight setup would be greatly appreciated!
No!!! Bad bad idea:thSick::thSick::thSick::thSick:I need to replace the tires anyway, but I might keep the back for winter tires and just fill the rim with concrete which would add some weight and come up with a suitcase weight wrack on the back.
:thanku: for all the replies!!!
Now that's really going old school!I might keep the back for winter tires and just fill the rim with concrete which would add some weight
That is much better than actually filling the tires. :trink39:When I said fill the rim with weight, I really meant make homemade wheel weights.
