Hi guys;
There are specialty forums for this, but all I get is people who want to sell me new material at 10X my budget.
Really nice looking, but it's not going to happen.
The project; In Amsterdam [Holland] I have a 12 ton 100 year old steel barge I use occasionally for work. Although I only need it rarely, when I need it I really need it.
max speed in the canals is 8mph, distance I need to travel is 3 miles on a charge. 6 would be nice, but the battery cost is another story.
Amsterdam has announced that all vessels must be emission free by 2026. Even now, I'm paying $500 per year penalty for having an internal combustion engine for propulsion.
So, getting to work;
Used forklift motor, 240A 48V, $200 second hand, available now.
pulse width modulated control, new $350, maybe a used one with the motor.
If the motor is 80% efficient [???] it's rated at 12HP. ok for going, a bit light for stopping.
I need some tech info on brush type motors. Amps/ volts / torque / RPM.
How do I achieve short duration overload capability for stopping + turning?
What happens if I gear the motor to turn the prop at 20HP at rated motor speed, then normally reduce that with a pulse width control to keep the rated amps at lower than rated speed?
Next subject;
water cooling.
this will be required even to let the motor run at rated power continuously.
I see 2 ways to do it;
1; add an outer jacket and use glycol solution to cool the motor casing, an intercooler, and 2 waterpumps. The boat already has an intercooler, and the diesel will stay in it for longer transits outside the eco restriction zone.
2; change the motor case for a stainless steel one, with waterjacket.
they're usually just a pipe. I have a lathe. The question that occurs to me is whether the motor needs the magnetic properties of the normal steel tube it's mounted in. 320 stainless isn't magnetic.
I have the time and skill [barely] to do the work.
Because the biggest heat problem is usually the armature windings, I have the idea to add cooling to the shaft; weld a stainless extension and run it through a water chamber.
Does anyone here have any knowledge of this sort of thing?
Next subject;
water cooling.
