Is it possible and safe to temporarily bypass the power steering on a tractor. I have a 65 4000 3 cyl gas, 4100 model.
My cylinder has a bad leak, took it off to have it rebuilt but don't have the cash this week for a rebuild kit which is about 70 bucks I'm told. Really need to get some firewood hauling and bush hogging done while the weather is pleasant. I fabricated an extension for my drag link because it wasn't long enough and tractor turns fine but im not sure about how the lines that normally go to and from cylinder need to be hooked up. Was told as long as I'm keeping fluid in the pump it'll be fine. I'm aware it isn't a permanent fix. Currently have the two lines connected together so the fluid goes back to reservoir but I don't want to run it and damage the pump till I know.
Also, something else I'd like to know pertains to the steering cylinder itself. When I removed it I had a seal kit I thought was the correct one which turned out not to be. I had already popped off the scraper on the piston rod and pulled out snap ring, washer retainer seal and seal spreader as instructed by the repair manual. Couldn't get seal in which led me to believe kit was the correct one. Stopped at 2 different businesses, one a tractor and parts dealer and the other an auto shop that also does cylinder work. Both said I needed the seal kit to rebuild entire cylinder not just piston rod seals. They said I needed to disassemble the from the control valve end where the hydraulic lines connect. However according to the manual I just need to do the piston rod seals. Help me out here....
