· One of the bad river boys
Starts and dies, will only run if In spray either in the carb. Took the carb. apart and cleaned it, same result, runs and dies. There is a white plastic piece on the carb. that looks like it had a hose attached. Carb. is pretty cheap so should I just replace he carb?
You're going to need Briggs part# 799583. These plastic carbs are a pain and I usually just replace them instead of trying to mess around with em.
