So, I've got a poulan pro push mower (briggs engine)that's maybe 2 years old. It starts after being primed & I pull start it, but only runs for a few seconds. After I had problems several times I decided that I needed to look into it.
So first off I found the filter to be pretty nasty & thought that maybe that was part of the problem. Cleaned it (it's a foam one), put it back in. After that I attempted to start it again... same problem. I checked into the primer bulb & whatnot everything seems to be doing what it's supposed to, I also took apart the top piece that the pull string attaches to & cleaned it out. I also lubed up the parts that spin the blades. After all that I figured that it would be fine. I put things back together & it ran for about a few seconds more than before.
Any ideas on what to look for? I'm fairly certain that it's something simple as I've had no problems with it & everything is pretty new.
