Positraction generally causes the tractor to slide sideways when traction is lost. Usually if one wheel breaks loose, the other will too and when that occurs the whole tractor turns sideways...instantly.
That is one of those ideas that sounds good but isn't. Now if it had a torsen differential, then that would be different.
http://en.wikipedia.org/wiki/Torsen
Steering brakes on a posi rear end is self defeating. The harder one brake is pressed, the more the diff corrects for it.
