1 - 9 of 9 Posts
Hi Guys,
I have a s21XXX f engine push mower that pops a few times when first cold started. It only does it maybe 5-10 times and then will not do it again. What causes this? The mower has real good power but seems like it gains rpm when warm also. Bad seals? I don't notice any leaking from the lower one but have not checked the upper. Thanks.
-Dave
Administrator
What I have seen with Lawnboys backfiring (if that's what you think it is) is ignition related. Had an older one that would start to rev up, back-fire, rev, back-fire, etc. Changed the coil (old one was cracked and beyond help) and i was off and running. If not the coil, maybe a bad plug or plug wire??
Keep us updated on what you find.
I think Brad is on the right track. It's probably timing related in the CDI module.
Thanks. I'll try a different coil and see if that cures the problem.
-dave
Or spark plug.
Walt Conner
Thanks, Walt. I will check into that one too. I don't know if the compression is low. It went through some very tall, thick wet grass with no problems.
-dave
Lawnboy Green
Hi Dave,
While you have the shroud off, look at the flywheel key to make sure it hasnt moved and advanced its timing a little.
Best wishes,
Bob
1 - 9 of 9 Posts
