Poor man's power steering 200 series
12654 Views 68 Replies 18 Participants Last post by  jayvee43
HI guys, it is just too cold outside today,
so I am spending a little time looking at old archives, and I was looking for the poor man's power steering thrust washers and thrust bearing solution.
I can't find anything for a 200 series tractor. :dunno:
So my question is: Is there a difference in size between the 200 series and the 400 series front axle wheel spindle shafts?
And what would be a good source supplier for them?
:thanku: Jay
1 - 20 of 69 Posts
Steering spindles on 400 series tractors are 1" OD thru the cast axle and reduced to 3/4" where the wheel is installed. 200 series tractors have a 3/4" OD spindle thruout the entire spindle.
Bob MacGregor in CT
Bob MacGregor in CT
:dunno: guess I didn't noticed that the last time I swapped wheels between the 224 and 446 after a blow-out thanks, Bob :fing32:
Bob MacGregor in CT
I second this. The rims and tires can be interchangleable but where the spindle goes thru the axle is larger on the 400 series.
So all you need is 3/4 thrust bearing and 2 hardened washers per side.
:thanku:
Did you guys use the .032 thick or the .125 thick?
Thanks,
Terry T
Is this applicable to the 446? I might as well do this when I put it all back together.
How long will an unprotected roller bearing last?
They have a dust cover for them I'm not sure if they are on that page or not. I think they should be ok without them as long as you keep a good quality grease on them. I'll let you know how it works and how long they last mine are on the way:fing32:
Thanks Bob Mac,
I figured the others would be to tall of a stack-up.
Again Thanks,
Terry T
Did you find that there was a fellow on the Toro site who did an upgrade on his Wheel Horse steering? Wheel Horse has a 3/4" spindle.
wseternmd,
I would deffinatly use the cup shield, It takes very little dirt to stop the mini rollers from turning resulting in skiding, If you keep the dirt out they will work good for a long time.:fing32: kubotakid
Another option is a brass bearing with graphite plugs in it.
McMaster Carr P/N 2855T5 for a 200/3000 series, 2855T7 for 400/4000 series tractors. One per spindle, no other washers needed.
Bob MacGregor in CT
Bob MacGregor in CT
I like this idea even better. The brass/graphite will take the abuse of grit and provide a slipperly surface. I am going to try and source some locally.:fing32:
http://www.mcmaster.com/#catalog/118/1135/=g8itol
I found this, is it what you are refering to?
I believe that is what he is refering to.
I've seen these used on compact mobile lift booms and they work well, even without regular lube.
I'm not sure if McMaster Carr ships to Canada. I have ordered and sent McMaster items to other Canadians. Let me know if I can help you.
Bob MacGregor in CT
Wow,
I ordered my two bearings yesterday after reading this thread. They arrived today! Now I just have to get the parts back from the media blaster, paint, reassemble - oh and rebuild the engine and I will be ready to go.
1 - 20 of 69 Posts
