Heloo fellow members, got a question for ya. I put up a pole building a few months back and have been watching for potential leaks and have a couple that won't go away. I posted a thread awhile back and most posters mentioned that part of the problem was the sweating that naturally occurs, but the two leaks I have that won't go away come around after moisture specifically. The one is on one side of the window opening and the moisture shows up on the rim board at the bottom of the framing of the window that connects to the rim board. The other leak is on a side wall and moisture again is evident on the rim board. I have inspeced the metal work and all looks good and on the window opening the metal was cut for the window opening, J channel installed, and the metal was screwed to the wood framing with the insulation sandwiched in between. The other window opening was done the same way and no trouble and becoming frustrated. Running out of ideas and patience and thought I would ask. Thanks
See less
