Polarizing
1445 Views 9 Replies 3 Participants Last post by  km3h
So I put a new (used) delco unit on, and the Gen light stays on while running.
Should I have polarized it first? (k321, '73 444)
1 - 10 of 10 Posts
err, got it, guess I figured it would stay polarized from the previous tractor.
Best part of the link
"never assume the generator is properly polarized. You must polarize the generator every time it is disconnected or serviced. "
Thanks Km3h, had to read your whole twin Deere lx tale again, evryone loves a great tractor parlay story. The 444 was the happy ending that was left out.
Yea
I love that 444. Stole it too. Right now it is a pile of steel waiting for sand blasting. Waiting for cooler weather next week to do it.
Hope things work out with the generator.
Found out why it didnt work.
The field coil was bad. So swapped the coil from my old one, combined with armature of the new one...and it works
Now to contact the seller and ask for some $ back....
Multimeter again saves the day
A good meter is worth its weight in gold when you need it. Glad it worked out for you.
Thk's for the "polarizing" link km3h
Beaumont { :>)) www.petperfectexpress.com
Golden Rule - "he who has the gold, makes the rule"
http://www.mytractorforum.com/showthread.php?t=135888 http://www.mytractorforum.com/showthread.php?t=136600&page=3
1992 JD 318 original paint w/484 hr. on P218g Onan & #49 snow blower / 1998 JD GT262 w/brand new Kawasaki OHV & 48" rebuilt deck
http://www.mytractorforum.com/showthread.php?t=135838
It was my pleasure. Glad you got it fixed.
Beaumont,
Thanks for reminding me of my lack of manners
Km3h, thanks for the link.
It's not over yet, the gen liight stays off @ idle, comes on @ throttleup.
I'm thinking brushes....I'll get a chance to look at it again in a few days.
Beaumont,
What is the voltage reading at idol and throttle-up at the generator and then at the voltage regulator output terminal? Also, make sure that you have very good connections, especially at ground. Many voltage drops are caused by a weak ground connection. Every ground connection is important.
1 - 10 of 10 Posts
