1 - 14 of 14 Posts
I ran the piping for my air distribution in my shop today.
I used all ¾” black pipe, and hung it all the way around using shallow unistrut with pipe hangers. I lag bolted the unistrut to the truss chords on the long sides and to the studs on the short sides.
I put drops with drain valves at two opposite corners, since each is a potential compressor location, as I wired both with 240v.
I used tee’s for all joints in straight runs, so I’d have the option of adding drops later if desired.
I put a drop where my welding table will be, in case I get a plasma cutter someday:
I hung my Lincoln hose reel. I have two other hose reel locations prepped, but my other reel is still in use in my Calif. Garage, and I am still searching for my third one.
The new workbench came in handy as a catch-all, for the vise when needed, and as a platform for the ladder.
Nice job Steve. Well thought out as ussual. You have a shop that is the envy of the forum, just ashame you don't have any tractors to work on lol. At least I didn't see any in the pics.
Looks great. Smart thinking using tees for joint connertors. Did you put in a flex joint between the compressor and supply line ?
MTF New Poster
Steevo,will those attachment points allow for expansion of the pipe?I ask this because of a shop I worked in.We had black iron pipes ran around the roof with 10 drops.The expansion from the heating and cooling made them pop really loud and would scare the **** out of people.Our pipes were held to the roof with u bolts through the steel trusses.
Old Stonebreaker
Steve, that's a real pro lookin' shop and pipe installation. I can't tell in the pics. Are you going to have a tee for the quik couplers on the drops and have a 6"-8" nipple w/ a drain valve below the tee for a water trap? That air system should outlast you!!
Mike
Once was a Super Member
Looks great!!!
Come on down and plumb mine:thThumbsU
Kinda hurts my feelings--I'm still rolling & unrolling air hose everyday,and triping over it as well.lol.You do good work fellow!Only question now is "Where's all your junk at??" Mine looks like an obstacle course.
Discussion Starter #13
There is one tractor in the shop right now:
It is an HT20 with a Johnson loader. (future project)
The other six tractors are currently filling up half of the 3-car garage on the house.
The bins in this pic are full of Bolens parts and there are a dozen more in the garage.
There is also an HT20 mower deck on top of my bathroom in this pic:
I have stuff spread everywhere.
I just haven't consolidated it all in one place.
Discussion Starter #14
Mike
Yes. You can see that better in this pic:
1 - 14 of 14 Posts
