1 - 9 of 9 Posts
Well folks, I finally figured out how to plug the chute on my ltx 1045. While mowing yesterday afternoon I went across some new sod that I had laid down. It was a bit on the dry side, and needed watering, I figured to mow first then water the lawn after. Well don't yah know if the new sod is a bit dry the high lift (normal) blades on the cub will lift the sod, and I lost about 2 ft or one roll before I was able to swerve off so I didn't lose any more......... The wife said there was a big cloud of dust, and I felt a bit of shaking then she settled down and was OK after that........ I was done with the lawn at that point any way, and was just making a few passes near a maple tree to pick up the whirl y birds that fall........ I have to drop the deck maybe tomorrow to make improvements to the chute for my tag along leaf pickup machine. The chute says it is made to fit about 50+ different tractors you just cut the shape you want. I feel that at this point it is so flimsy that I want to make it stiff enough so it will attach/detach the same as the regular chute of my bagger....... I have a plastic welding kit so if I need to I can add plastic to stiffen it........
Dave, wasn't that sod pinned down? j/k Well anyway, at least the chute is plugged.
I have never pinned sod in place. I didn't know that you should, or had to.... What would you use to pin it down with any way. I laid 300 sq ft in the front, but I watered it kind of heavy for about 2 weeks, even at that I didn't run over it with the tractor until it needed mowing a few weeks ago. The stuff in the back was just laid, and I wanted to get the lawn mowed first before watering. I have the chute up at 3" at the moment, not sure if I want to raise it any more or not yet. I know that with my sand in July I will be raising the deck to the top notch so it will get as much shade to hold moisture as it can......... When I first moved in here 26+ years ago, the only thing I had green in this yard was weeds, and wild strawberries, and lots, and lots of sand..... The bits of grass I had coming up in one portion of the yard, I stopped mowing around the 15th of June, then didn't mow it again until it went to seed. After several years I started to see more, and more grass. However back then I could not afford to water, of even feed the lawn like I am now........
OK I'll bite what is J/K????????
Tech Nerd Tractor Convert
Actually it means "Just Kidding".
But who knows, maybe you're on to something.. you could invent a sod tiedown or glue for just this situation and be the next millionaire...
Might want to stick to the walk-behind mower until the sod takes root.
Your to late on that idea. You can buy things called "Sod Staples".
AJ
AJ
Staples are generally used when sod is placed on a grade, or slope to help hold it in position IIRC.
1 - 9 of 9 Posts
