1 - 3 of 3 Posts
I'm checking out my 7260a lawnboy and i'm replacing the seal and so on.How much play is too much for the shaft? Thanks for your help.
5K Poster!!!!
If the run-out exceeds the max. limit then you can bore the lower end to accept either an F series needle bearing set or you can use the same needle bearing that is in your upper end. There are quite a few threads on here about that and if that is what you need to do then we got you covered.:thThumbsU
1 - 3 of 3 Posts
