Hi all! Anyone have or use a piston stop when working on their mowers or other lawn equipment? I have done the rope in the cylinder trick when trying to remove a clutch on a 2 cycle trimmer but thought for the cost investment it might be nice to buy one of these. They are listed as no longer available as a Lawnboy part but I have been able to find a lot of aftermarket ones. I see some have a center adjustment feature as well. Any thoughts whether these are worth having. I know when trying to remove the blade on a mower the "hold the blade with a rag method while turning the nut" isn't always the best choice and I have tried the "wedge a piece of wood in there method" and that doesn't always work either. How do you know what length to buy or are they standard or would the adjustable one be a better choice and if so, why. Also, while on the subject of service tools, I have been thinking of some additional specialty tools to have for servicing the mowers. I would really like a seal puller although I don't do enough seals to warrant buying one at this time. I know a lot of you use a piece of pipe to set your seals and I have done this but the Lawnboy tool sets the depth the same all the time. I may try to find a way to modify my seal setting pipe so it has a depth stop. Also would really like a small tach for checking the mowers. I have researched and have seen everything from $150.00 handheld digital tachs to the mechanical Vibratach. Have see a few that look like they are supposed to be mounted to the equipment and give RPM and hours. The wire wraps around the plug wire and the unit is grounded. Anyone use one of these as they appear to be a good value for the price but I don't think they are resettable. Give me your thoughts as to the best and most accurate and easy to use tach for the best price. Thanks, Bill
