1 - 20 of 24 Posts
John Deere 445
I picked these up about a month ago at a auction. I was hoping they would slide into the rim but they don't. They are Redlandhill 4150 http://www.redlandhill.com/weights.html 70 lbs. each. What do you think little ugly.
I'm thinking i need a second coat hanger and a couple pieces bubble gum to secure them. :thThumbsU
:thSick:
Drill a coupler of holes where you need them. Throw on some JD Yellow and your good to go with those.
:ditto: Some bolts, some paint and you are good to go. :thThumbsU
USMC
They may never look right on that tractor, go ahead and send them to me. Seriously, they are great, follow the others' advice. If your still not happy, send them to me.
if you can get them on, I think they look just fine!
got to be a tough one drilling 8 holes through those though... I am assuming they are solid 3-4" steel??
if you got the drill, I am sure you can make them work well...
John Deere 445
Discussion Starter #9
Thanks everyone, I never cared for the weight sticking out look, But these are starting to grow on me.
The mounting holes line up fine. No need to drill new holes.
I think if i clean them up and spray some JD yellow I'll be happy with them.
They look fine. Painted yellow the distance out will be less noticeable. I imagine it's hard to get 70# without getting out from the rim, that's a lot of weight. Congrats on the good find.:fing32:
John Deere 445
Discussion Starter #11
Had a chance to clean up and add couple coats of JD yellow paint. Went form kinda ugly to kinda pretty in no time. Just need to pickup some hardware.
Quite a transformation, they look great. :thThumbsU
John Deere 445
Discussion Starter #14
Anyone know how much Redlandhill gets for these weights.
John Deere 445
Discussion Starter #16
Thanks TurtleBoy,
I was thinking i had them for $5 but someone ran me up to 17.50 :fing32:
Thanks TurtleBoy,
You got a great deal on them. :thThumbsU
The John Deere Gods are giving you a big thumbs up after the restoration job you did in those weights.
Once you loose the baling wire, and get them bolted on properly.. Post a picture, I wold like to see how well they attach Thanks...
John Deere 445
Discussion Starter #20
Some pics. mounted. Two bolts good or do i need four?
1 - 20 of 24 Posts
