I just Did the coil upgrade to can coil, It was well worth it. after I did it, the old girl fired right up, then died, I ran a wire from the Battery to the + term on the coil, it fired right up and stayed running, HUM Must have a short in the wiring harness. I wiggled it a little removed the jumper while it was running and it stayed running but ran like crap,, missing like it did before all of this.. must be a voltage problem, enough to let it run, but not enough to run right.
Any How here you go::::
first remove the coil and cut the riviots off,, I used a die grinder.
