Ok looked at two tractors and this one followed me home. 1987 318 with 1500 hrs on the onan. Runs perfect just needs a little TLC. pto wiring is shorted somewhere I believe at switch but jumped it at the clutch and it works fine. Motor is a little oily but nothing major. Mower deck has a broken lift arm( anyone have one to sell?) should make a nice machine once cleaned up and serviced.
If anyone has any used parts connection I will need a deck lift bar first off.
Don't you think that can be welded?
Smalljob
I misread your post and thought you said you didn't think that could be welded. I was going to say I have several the PO welded. I couldn't do it but several put a bar beside the break. Cut out to go over the rod and put a bar on both sides.
