You're on the right track by pulling that 15 amp fuse. You may already know this, but your problem is often called "parasitic draw" or "parasitic drain." If you want to search around more for pointers on your problem, using those terms will probably help.
The normal procedure for figuring out what is causing the draw is to make sure any electrical accessories (headlights, etc.) are turned off, unhook the negative battery cable and place an ammeter in series from the negative cable to the negative terminal of the battery. The reading you get will show how many amps you are drawing. "Normal" values here, assuming there is something on your tractor that would always draw some current with the key off (a computer, as Tudor suggested), will be on the order of a few milliamps. Anything beyond that is a source of concern. In your case, I would expect you to see a few tenths of an amp draw.
From there, one would remove a fuse and check if the ammeter reading drops. If not, replace the fuse and remove another one. In your case, it seems you have it pinpointed to the 15 amp fuse. Doing this test with your 15 amp fuse installed, then removed (and observing the resultant amp drop), would confirm the culprit is in that circuit.
After that, it's a matter of determining what is on that 15 amp circuit (an owners manual should give some insight), and then systematically unhooking the various components on that circuit to pinpoint the actual culprit.
It may seem cumbersome, but when you get in the decision tree mindset by narrowing down fuses then components, it isn't so bad.
