I've owned a JD 170 for several years now. The previous owner (PO) ran it hard and put it away wet. It also had the failing powder coat and rust on the fender deck. A few weeks back I started fixing it up so it would last several more years. That's when I came across another 170 on craigslist described as "bad transaxle, no forward gears". I went and bought it to have for a parts tractor. But.... its in better shape than mine except for the tranny so I started researching the transaxle and looked through the Tecumseh repair manual you can find online. The transaxle looked simple enough to me.
http://www.smallenginesuppliers.com...eh/Tecumseh_Transaxle_Service_Information.pdf
My other JD 170 has this transaxle:
The symptoms:
The tractor drives in reverse fine. No noises, grinding, ect.... In any forward gear it would grind. Shifting felt a little sloppy, but you could still feel the separation between gears.
So I removed the fender deck and looked over the shift linkage. The bolt holding the shift arm on the tranny was loose causing a little slop in the linkage. I knew it wasn't the entire problem but I tightened it up and did some further investigating.
The tranny would now shift into every gear, and you could run it by hand with the rear wheels off the ground and it worked fine. But if you held the wheel and tried to turn the input pulley then after a bit of pressure the tranny would pop and slip of sorts. Not knowing how this thing ticked, I was thinking maybe it was jumping gear teeth.
So I removed the tranny from the tractor. Right off I found the input shaft had a little too much up and down play. I removed the pulley and found the clip ring and its washer had ground away some of the tranny case and the input pulley. I'm still thinking through how I'll repair this. Ideas are just a simple shim washer or maybe a thrust bearing, or ???
I pulled the top off the transaxle and found the grease had separated and some of the oily component was on the gears, but the solids were all caked in the bottom of the housing. All the gears, bushings, bearings, ect... looked good. So I played with it for a bit learning how it works. (Yes that red stuff is my blood. Don't try and shift these with your fingers, the keyway edges are sharp):00000061:
Then I pulled it apart to look at the shift forks (this one has 4). There I found the issue. The tips of the shift forks are rounded off.
This is the shift keys and an axle end bearing. Looking at the manual, this it the "heavy duty" version of 4 possible axle bearing setups.
Seeing how these forks interact with the keyways in the gears I pulled all the gears and look them over. All are pristine except for 3rd. It has the inside corners of the keyways ground up a bit. I'll likely not replace 3rd gear. I do most of my mowing in second, and the damage is minimal and not where they shift keys should contact if you don't shift on the fly. I suspect the PO did most of his mowing in 3rd and either had the clutch adjusted wrong, or did some shifting on the move.
Having pulled this thing apart and playing with it I now understand the quirks of these things, why forward gears fail, and why reverse doesn't.
The shift keys ride in keyways on the gear shaft. They are bent so they have a spring action on the tips for the forward gears. The forward gears lock in by the little triangle tips of the shift keys. As you move from gear to gear the spring tips get compressed into the shaft keyway and then spring out to engage the keyway of the selected gear. If the edges of these tips get worn down then the force of the gear turning just pushes them back down into the axle keyway and the gear spins. The grinding you hear is the shift keys grabbing each keyway in the gear and then getting compressed back down and popping over to the next keyway as the gear spins.
The reverse gear uses the back of the keys that are square and not spring action. That explains why I sometimes have to let the clutch out a little to get into reverse. There is no ramps. You have to spin the shaft till the keys line up with the slots in the gear. Reverse doesn't break because the keys fully fill the shaft keyway and the gear keyway. The reverse gear/key/shaft engagement is much stronger than the forward gear setup.
So I'm looking for a source for Peerless parts. Shift keys and bushings primarily. I see Sears lists lots of parts, but prices seem rather steep and the description for the keys doesn't say if its a 2 key set, or just a single.
I'll put new keys, new bushings (these have a little play), and new axle bearings (just because) in this. I'll likely not replace the 3rd shift gear unless I find it for a good price. I'll fill this with a blend of Bentonite grease and Lucas oil stabilizer.
After I get this one back together I'll pull apart my other Transaxle and do an R&R on it. Its the same age so I suspect the grease is in similar condition.
The symptoms:
