1 - 11 of 11 Posts
Hello!
I have a 2004-2005 Husqvarna LT151 wich looks to be the same as the Craftsman 917.273811.
The Peerless 206-545C appears to not have reverse or 1st gear.
Now I have it apart for the second time to try and fix it.
Any tips would be appreciated.
Thanks
-Yngve
Have been looking more at the gears today.
Reverse, 1st, 4th and 6th looks to need replacement. Chipped inner teeth, and scratches.
2446069
And the "shift key's" look rounded over on one side.
Looks like you may have some burring on the shaft, might be able to clean it up with light emery cloth cleaning. I'd replace anything that looks worn or chipped.
Yes, no oil change in 15 years might do that...
It's not too bad. So I guess I could polish it away.
Was thinking the same.
Have to order from the US then. Just have to find the best place to order the parts...
I also need the bushings and seals for the whole thing. And one wheel axle (left? have to check. can't remember)...
Was also considering putting in the optional bearings that would be at the end of the wheel axels.
1 - 11 of 11 Posts
