Forgot to mention. It's a JD x580
Sent from my SM-N920V using Tapatalk
Yes, I do have the front rockshaft installed for the front lift for the snow blower . I was in the process of removing the blower when this happened. I haven't been out there today, but I'll check on it as soon as I get out there, thanks a lot for the reply and the suggestionIt sounds like something is out of place and thinigs are binding
Check the linkage for the forward/reverse pedals as well as the brake pedal. Follow them from the pedals back the the trans to make sure that nothing is interfering with their movement.
Do you have the front rockshaft installed for the front lift for the snow blower or plow? If so, check the linkage connecting the front rockshaft to the main rockshaft for the mower deck lift. I had that come disconnected at the front end and it dropped down and interfered with the steering linkage. I'm not sure what it might interfere with if the rear end came loose and dropped down.
