21 - 40 of 76 Posts
Discussion Starter #21
I have two comments.
1 - Microsoft does not guarantee that old files will work with future versions. I don't know what the solution is.
Personally, my solution is to avoid M$. I find that other technologies almost always work better with less hassle. But I recognize that that doesn't work for many people.
Maybe avoiding a spreadsheet is best. I think that a small database with a web front end would be better. That way when someone does find a single cross, they can add it without any sending of emails (where is that email address? What is that guys name?), etc.
No argument. I thought about doing that, but decided to stick to my usual software engineering dictum, and not pre-optimize.
It may be that you're right, and we'll end up with enough traffic and updates that managing a spreadsheet will become unwieldy. In that case it will certainly be worth stuffing it all in a DB. That would actually be quite a good problem to have :)
2 - Some of data in the cross ref is questionable. Bearing cross references can be a minefield..
Yes, no argument to that either. Again, I figured something was better than nothing. If there are updates and/or refinements to what's there now, great, let's capture them.
It should go without saying that anybody using this data is expected to use some common sense and skepticism. Check those specs before ordering!
Ron,
Give me a call when you are free.
Old Iron Connoisseur
Just something to add... it is either Stant 11623 or 10623 that is an L/C/800/8000 Gas cap replacement. I can't remember which one it was or maybe that was a running number change.
Active member, now deceased, but not forgotten.
I love this idea - I hope it will work, even with some cautions.
I Love All Color Tractors
Try uploading your spreadsheet in it's .xls format now, JRD. I think we have the software set to accept it now. If it won't take, let me know.
Discussion Starter #27
Ok, let's try this again. Here's the parts crossref as a spreadsheet. Mostly the same content as before, with a couple of additions.
It opened right up for me too. Do you want to replace Chip's email address in it with yours?
Discussion Starter #31
Yeah, probly should. I've got a couple more updates, will fix that too when I get the next rev out.
Just testing, I'll delete if it doesn't work. Saved as a text file. Does this work?
GRAVELY SEAL & BEARING CROSS-REFERENCE
"The information below is based on an undated cross-reference guide published by Gravely,"
with additions contributed by the Gravely owner community. The original Gravely document
"was in poor condition and poorly formatted, so ratherthan simply scan the original | have"
"recreated it in a more usable format. Every e_ort has been made to ensure accuracy, but |"
guarantee nothing. Use at your own risk.
"The Gravely part numbers shown are the revised numbers used starting about 1968. Sorry,"
| do not have a cross-reference to the old-style Gravely part numbers.
"Please send additions, corrections and comments to me via e-mail."
Chip Old <[email protected]>
Hacked and added to by jrd
Gravely P/N What Manufacturer Manufacturer P/N N req'd URL Notes
5139 Bearing Hoover 87003RS
5139 Bearing American Koyo 8008
5139 Bearing Fafnir 38XVLD
5139 Bearing MRC 38FSF
5139 Bearing Torrington NTA-2840
6423 Bearing Torrington TRA-2840
6741 Bearing Bremen (SKF) BT 1220-5-24
6742 Bearing Bremen (SKF) TW 1220-4
6743 Bearing Bremen (SKF) BT 3244-5-54
6744 Bearing Bremen (SKF) TW 3244-6
9206 Seal Garlock 63x427
9206 Seal Timken (National) 471766
9245 Bearing Timken L44610
9246 Bearing Timken L44643
9660 Bearing Torrington B-128
9661 Bearing Torrington NTC-1427
9662 Bearing Torrington TRO-1427
9667 Seal Garlock 94x6120
10389 Bearing Timken LM67O48
10390 Bearing Timken LM67O1O
10509 Bearing Bremen (SKF) 6204
10509 Bearing Fafnir 204KLL2
11063 Bearing Torrington B-1212
11164 Bearing Torrington B-1612
11222 Bearing Torrington NTH-1220
11224 Bearing Torrington TRO-1220
11225 Bearing Torrington NTH-1625
11226 Bearing Torrington TRO-1625
11227 Bearing Torrington B-168
11235 Bearing Torrington B-1412
11604 Bearing Torrington B-148
12332 Bearing Timken 2875
12333 Bearing Timken 2820
12404 Bearing Torrington TRO-2840
12489 Seal Garlock 63x8704R1
12493 Bearing Hoover 993L06
12493 Bearing American Koyo 6006x2RS
12494 Bearing American Koyo 6206
12500 Bearing Timken 399-A
12501 Bearing Timken 394-A
12511 Bearing NICE 513 old Gravely p/N A34O
12517 Bearing Fafnir 205TT
12590 Seal Chicago Rawhide 514999 Late L axle seal (1.5 in OD) Proprietary number sold only through Gravely.
12590 Seal Chicago Rawhide 9843 Late L axle seal (1.5 in OD) Same seal as CR 514999 but not proprietary. OD) Same seal as CR
12622 Seal Garlock 78x141
12626 Bearing Bremen (SKF) 6202
12626 Bearing Fafnir 202K
12626 Bearing American Koyo 6202
12833 Seal Chicago Rawhide 19237
12984 Bearing American Koyo 6305
12987 Seal Garlock 63x215
12987 Seal Chicago Rawhide 8748
12996 Seal Chicago Rawhide 9929 Early L axle seal (1.625 inch OD) OD)
13042 Air filter L-832-E 1 http://gtgravelyparts.com/products.html
13042 Air filter Napa 2302 1
13042 Air filter Wix 42302 1
13107 Bearing Steyr 6305A
13107 Bearing New Departure 3305
13122 Seal Garlock 63x175
13122 Seal Chicago Rawhide 8017
13122 Seal Timken (National) 471539
13139 Bearing Timken 15245
13140 Bearing Timken 18720
13141 Bearing Timken 18790
13142 Bearing Timken 15113
13143 Bearing Timken 9195
13144 Bearing Timken 9081
13145 Bearing Timken 7196
13146 Bearing Timken 8087
13171 Seal Garlock 94x5091
13171 Seal Chicago Rawhide 13812
13171 Seal Timken (National) 471 276 "Mower drive bottom seal, Models 58-A, 185, 106 B newer."
13421 Bearing Timken 387
13422 Bearing Timken 383
13464 Bearing Bremen (SKF) 6206
13464 Bearing American Koyo 6206x2RS
13491 Seal Garlock 63x4700R1
13520 Bearing Torrington B-1616
13524 Bearing Bremen (SKF) 6304
13524 Bearing Fafnir 304K
13560 Bearing American Koyo 6206xRS
13590 Bearing Fafnir 205KLIG2
13593 Seal Garlock 63x7691
13593 Seal Chicago Rawhide 22448
13594 Bearing Timken 1755
13595 Bearing Timken 1729
13597 Bearing Bremen (SKF) 6205ARS
13833 Bearing Timken 1986
13834 Bearing Timken 1932
13890 Bearing Fafnir 204KTT
13894 Bearing Timken T4955O
13898 Seal Garlock 229
13899 Seal Garlock 301
13900 Bearing Timken 1986
13901 Bearing Timken 1931
13902 Bearing Timken T49569
13905 Seal Garlock 51
14066 Seal Garlock 63x6674R1
14067 Seal Garlock 63x6675R1
14070 Bearing Timken 15123
14071 Bearing Timken 15245
14072 Bearing Timken 1780
14075 Bearing Timken 15100
14083 Seal Timken (National) 471 763 Model 58 mowerdrive bottom seal.
14096 Bearing Fafnir LAK1
14390 Bearing Bremen (SKF) 6205A2RS
14564 Bearing Timken 14274
14565 Bearing Timken 14125A
14640 Bearing Timken L44634 cone L4461O cup
14644 Bearing Timken LM11949 cone LM1191O cup
14645 Seal Timken (National) 474278
14646 Seal Timken (National) 471750
18031 Seal Timken (National) 450165 800 axle bearing seal.
18042 Bearing NTN 6208LU
18341 Bearing "Torrington, Timken, Koyo" NTA-1828
18342 Bearing "Torrington, Timken, Koyo" TRB-1828
18445 Bearing Timken LM1191O
18446 Bearing Timken LM11949
18447 Seal Timken (National) 205005
18961 Seal Chicago Rawhide 14876
32050 Bearing SKF 8390
12626P1 Bearing 6202 2 http://www.vxb.com/page/bearings/PROD/Kit12686 800 hydraulic pump driveshaft
14640a1 Bearing Timken L44634 cone L4461O cup 2 800 PTO output bearing: Two tapered rollers back to back.
17914p1 Bearing 6010 2 http://www.vxb.com/page/bearings/PROD/Kit12842 800 cluthc hub bearing
17917p1 seal National 473214 2 http://www.rockauto.com/catalog/raframecatalog.php?catalog=13&partnum=473214&a=FR13-473214-35553 "800 clutch hub seal, not exact match"
17917p1 seal National 411000 2 "800 clutch hub seal, not exact match"
17923p1 seal National 471192 1 http://www.rockauto.com/catalog/raframecatalog.php?catalog=13&partnum=471192&a=FR13-471192-29069 800 pto output seal
17967p1 Bearing 6207NR 1 http://www.vxb.com/page/bearings/PROD/Kit9903 "800 PTO main bearing, snap ring"
17973p1 seal National 470954 1 http://www.rockauto.com/catalog/raframecatalog.php?catalog=13&partnum=471192&a=FR13-471192-29069 800 pto clutch front seal
17984p1 Bearing 6207 2 http://www.vxb.com/page/bearings/PROD/kit8528 800 differential bearing
18029p1 Bearing ??? 2 800 axle outer bearings: no exact match available?
18031p1 seal National 450165 2 http://www.plccenter.com/Buy/NATIONAL SEAL/450165 800 axle bearing seal.
18035P1 seal National 470954 2 800 clutch hub internal seal
19741P1 Bearing Timken RAL100NPP 1 Snowblower 38/44” input shaft
9660p1 Bearing http://www.vxb.com/page/bearings/PROD/Kit11902 800 PTO needle bearing
L-841 Air hose Autozone 70885 1 This hose can be cut in half to make two servicable L hoses
I have a FRAM CA-77 air filter that I just pulled out of my new '69 C8 (7.6 engine).
Does anyone have any numbers for L Model gas caps?
Discussion Starter #35
I don't offhand, but I've seen folks reference them.
If somebody has a replacement, please email me and I'll update the spreadsheet.
Information for MA-115 Snow Blower.
When I refurbished my Snowblower I found a Bearing and Seals locally at Akron Bearing.
From the Deluxe Snow Blower Model MA-115, IPL dated July 1, 1967:
Exploded View No. 65, Part No. OS 108 Oil Seal: C/R 12545
No. 87, Part No. OS 109 Oil Seal: C/R 12577
No. 30, Parn No. BB 106 Bearing: KOYO 6206-2RD
Hope this helps someone else.
Joe.
Discussion Starter #37
Thanks for the updates. I added them to the spreadsheet. Do you have a vendor where you got the seals?
Good Afternoon,
I have been able to use them for all my Bearing and Seal needs.
Akron Bearing
1965 S. Arlington Rd., PO Box 7159, Akron, Ohio 44306-0159
Hours: Monday-Friday 7:00AM-5PM, Saturday 8:00AM-12Noon
Phone: 330-773-6855 | Toll Free: 1-800-686-9540 | Fax: 330-773-0126 | Email: [email protected]
Take care.
Joe
Discussion Starter #39
What about L model handgrips? Richard's has large black and white, GTGravelys has all white but also has control lever grips. Where would you get red grips or small black grips?
21 - 40 of 76 Posts
