The trick to working with any paint is to make sure it is thin enough that the gun will atomize the material but not so thin that the integrity of the coating is compromised.
While SW specifically states not to thin/reduce Acrolon more than 10% I have been running closer to 15% with no ill effects so far.
SW sells 1 qt mixing cups with ratios printed on the side. Those work well when mixing the hardener and thinner. Mix up about 3/4 of a quart of paint and hardener and then add thinner and when done the total is almost 1qt of paint. I went through about 2 quarts of paint painting the following:
30" mower deck. top and bottom
50" deck - top and bottom of deck and top and bottom of stiffening plate
old power brush including the brush guard.
plow drive
30" mower drive
a-frame for 50" deck
Two extended front guards for 30" mower - top and bottom
rear guard for 30" deck ( the wide one) inside and out.
Rotary plow dirt deflector/shield.
two long style 30" deck skids
A few misc small pieces
There was a fair amount of surface area involved. I would say that 2 quarts would do a 4 wheel tractor and have some left over.
The Devilbiss cup liners are great. They allow me to paint in any direction, even upside down with no paint spills. Makes cleanup a lot easier too.
Next week I will strip and repaint a new style cultivator, another 30" deck, a 50" deck or two, a steering sulky, and a snow plow or two for a 2 wheel tractor. Why paint the snow plow if I almost never see snow? It is just sitting there rusting and there is no point in letting it sit and rot away.
The better SW stores have a deal on respirators/filters. Buy the filters and they give you the respirator free. The respirator is actually pretty good. When painting I can smell nothing except clean air. There are a variety of filter types available. They don't have them out front. You have to ask about it.
