OTC Cab
1097 Views 4 Replies 4 Participants Last post by  JD75
I know it's early to be talking about cabs and winter. I currently have a 4 sided JD Weather Enclosure for my X500. I worked well for me last winter. When I took it off for spring I noticed the magnets did some damage to the paint on the fender and the door did some paint damage from rubbing too.
I'm looking at the OTC now. My question is, does it do any damage to the paint or scuff the metal at all
2012 X500
Fimco 15 gal sprayer
44' snow plow
42' lawn sweeper
Steel cart
Don't know the answer to your question but I can provide an observation from some past threads here. Many guys use a second beater fender pan just for winter/cabs and keep a pristine fender deck for summer. Just a thought. I bet it's cheaper by far than a new cab.
A-HA! I suspected as much but wasn't sure. I thought I was being a lunatic but now . . . the gloves are off and the welder is coming out! Well, perhaps by late winter :fing32:
The quick answer is no - but you have to remove the foot pads and bolt it on so yes you could have some scratches on the foot rest area. And if you want to put them back on you will need to notch them out. I leave my off during the winter. Also a good idea to have someone assist you will putting it on and taking it off. It is not real heavy but awkward so it could get away from you and scratch your tractor. I’ve had my OTC cab now for two winters and like it. If you get one I would recommend the upgrade to the hard windshield.
Thanks for the replies. I'll probably go with the new cab, if it does scratch it'll be covered up. Might put rubber washers or something to keep it from scratching.
2012 X500
44' snow plow
42' lawn sweeper
Steel cart
