1 - 3 of 3 Posts
What was the color scheme for the H14 1456?
1. Hood and fenders?
2. Rims?
3. frame and running gear?
I cannot tell if the color was white or the Bolens "beige", the hood has lots of surface rust and the current colors are:
- Hood and fenders over sprayed with bright white.
- The front and rear rims over sprayed with bright white.
- The frame, side tin, and rear box is black
- The front axle and steering gear is dark green.
I understand the late large frames had dark green front axle units, so heaven knows how many tractors this is made from. Frankentractor?:eek:mg:
Eleven Year Site Sponsor
The H14 had bright white hood, fender pan, and wheels. Everything else was black, including the front axle. A Large Frame front axle would not fit on a tubeframe like the H14, so somebody painted it that color for some unknown reason.
Doug
White? Ok, that makes it a bit easier to match.
Thanks much for the info,
DougL
1 - 3 of 3 Posts
