I am far from even being limited expert, but everything I have learned is that 2nd and more coats need to be applied no longer than a hour after the first coat. If you wait longer, then you have to wait, usually days, for that coat to completely dry to recoat.
That pretty well sums it up, Sonny.
Orange Peel is tough to diagnose
before it's happening for even a well learned painter.
The most common causes are from, IMO, one of the best written trouble shooting (Orange Peel) guides by DuPont:
Origin and Potential Causes:
Improper gun adjustment and techniques. Too little air pressure, wide fan patterns or spraying at excessive gun distances causes droplets to become too dry during their travel time to the work surface and they remain as formed by gun nozzle.
Extreme shop temperature. When air temperature is too high, droplets lose more solvent and dry out before they can flow and level properly.
Improper dry. Gun fanning before paint droplets have a chance to flow together will cause orange peel.
Improper flash or recoat time between coats. If first coats of enamel are allowed to become too dry, solvent in the paint droplets of following coats will be absorbed into the first coat before proper flow is achieved.
Wrong thinner or reducer. Under-diluted paint or paint thinned with fast evaporating thinners or reducers causes the atomized droplets to become too dry before reaching the surface. Too high viscosity.
Low shop temperature.
Too little thinner or reducer.
Materials not uniformly mixed. Many finishes are formulated with components that aid coalescence. If these are not properly mixed, orange peel will result.
Substrate not sanded thoroughly
Prevention Techniques:
Use proper gun adjustments, techniques, and air pressure.
Schedule painting to avoid temperature and humidity extremes.
Select the thinner or reducer that is suitable for existing conditions. The use of a slower evaporating thinner or reducer will overcome this.
Allow sufficient flash and dry time. Do not dry by fanning.
Allow proper drying time for undercoats and topcoats. Not too long or not too short.
Reduce to recommended viscosity with proper thinner/reducer.
Stir all pigmented undercoats and topcoats thoroughly.
Prepare and sand substrate correctly.
Follow recommendations on technical data sheets.
IMHO
, It's nearly always #1 -
Improper gun adjustment and techniques. And, usually either waiting too long, or not long enough between flash times (the drying time between shooting coasts of material). It's absolutely essential that the paint material is thinned correctly and applied so each coat 'melts' the former coat and flows out to it's maximum. This serves two important functions. It allows the solvents to evaporate properly (Gas out) and promotes thorough chemical adhesion.
Here is a link to the quotes above:
http://pc.dupont.com/dpc/en/US/html/visitor/s/trouble/PDSG_OrangePeel.html
Keep us posted as we have many folks that are darn good painters at MTF :fing32:
