Ok guys I need your opinions on something, I want to fill my 23x10.50 with some fluid for weight but here is my question I only want to do this so I dont have to mess with wheel weight brackets I have(bolt on the rim and you use dumbbell weights) and I dont have wheel weights to use. But the only time I ever need weight on the tractor is the winter time, I do mow with it but I have no hills and I live in town so I dont do much work with it other than hauling around a wagon. So seeing as I only need it for winter do you think that would justify filling the tires or should I just keep using the wheel brackets? I should tell you that there are a pain to put on and take off because of the brakes(cub 1862) the bolts are hard to get too and the one thing I dont like is they stick out from the tire and I forget how far they stick out and hit stuff with them or when the tractor is in the garage they are just the right height off the ground to be shin busters(I have hit them a couple times) so opinions please
