1 - 14 of 14 Posts
I was trying to grease one of the rear height adjusters on my Toro and broke the zerk fitting off :banghead3 At least I broke it off AFTER I greased it!
Will it be okay to use in the meantime, until I can get another adjuster? I'll find something to plug-up where the zerk was.
Bryan Was it a drive-in zerk or was it threaded?
OMC & Ariens lover!
ive had that fear,when my grease gun locks on to it theres almost no way of getting it to let go.
lol all you need is as good violent pull lmao
That's what happened to me, my grease gun locked on and wouldn't let go! I'm not sure whether its a drive-in one or screw-in. I think its a drive-in, because the base of it isn't hex shaped, like most of the screw-in ones I've seen.
The voice of reason !
You may be able to get it out and save a little money by changing just the zerk.
OMC & Ariens lover!
Discussion Starter · #9 ·
An easy-out should work if it's threaded. If all else fails, a new adjuster is only $15.00
drill out the old body&tap for a thd, zerk
I would either drill out and retap as stated above, or look for a used piece that you can use, or buy new, or leave it alone and take apart and grease. I'm not sure if you will be able to get the grease in all the right places by taking it apart. Good luck
1 - 14 of 14 Posts
