Ooops what did I break (LawnBoy bad mixture)
1068 Views 5 Replies 5 Participants Last post by  twmattox
I have a Lawn Boy "V" series franken mower. Basically a run of the mill V bolted to an old Duraforce deck. Has run GREAT for YEARS. This year had some hard start issues so I bought a new coil. Again, things were great. Well, I ran out of my stash of LawnBoy Generation II cans and went in and bought a couple of those "newer" plastic bottles of LawnBoy oil. Well, I guess I didn't think to read the label and just poured one can in and added 2-gallons of gas. Apparently, this only made a 64:1 mix... Well, I made it through 2 mows before the engine started making a horrible rattle and seized up. That's when I realized what a horrible mistake I made. I feel horrible!
So, I guess I will be tearing into this when I get a chance over the winter. I am just curious what I may find.
On a side note, maybe that particular deck is just cursed. I was given the deck by my wife's friend because she straight gassed the Duraforce after she mowed her lawn for the first time post divorce(she didn't know she was supposed to mix the gas for it).
1 - 6 of 6 Posts
Karma will not let me reply beyond the question;
The x-wife stole his lawnmower and broke it while her new boyfriend attempted to mow the lawn she stole from the man who lost it all to her and a diseased legal system?
Take the spark plug out and pour some 2 cycle oil or Marvel mystery oil down it. let it sit for a few days and try and break the piston free. If you open it up you will probably find a scored up piston and rings. Hopefully you will be able to hone the cylinder and throw new piston and rings, and seals in it. You may need bearings as well. Provided the cylinder/crank and rod are still ok...
Proof through field trial that oil ratios matter, sorry to hear that, go ahead and fix it.
I ran my john deere 12sb all last year on 60:1 with semi synthetic mix and it didn't blow up. If I ran 50:1 or more it would smoke like crazy.
Not sure what you mean... but, her ex wanted a "new mower" and gave her the old LB in the divorce...just didn't tell her she had to use 2-cycle gas in it.
1 - 6 of 6 Posts
