Merrie . You need to figure out some bet that you can make that you know for sure you can win to get it back .... We still have no snow yet .
Mike
Mike
Ditto that one, all bets are off.... Part of the deal with the Rings!!:trink40:A bet is a bet, but when it comes to husband/wife bets, they don't count like other bets do, so knock him off YOUR B100! :trink39:
That is my take, and sticking to it.![]()
ahh....yes, the three ring of marriage:Ditto that one, all bets are off.... Part of the deal with the Rings!!:trink40:
*ahh....yes, the three ring of marriage:
1) the engagement ring
2) the wedding ring
3) the suffering
:sidelaugh
Na.... I'll let him keep it, since he got rid of his Cub (what a mistake thatMerrie . You need to figure out some bet that you can make that you know for sure you can win to get it back .... We still have no snow yet .
Mike
WOW, I never thought about that, don't know why :dunno: He putUh, Merrie, I think Rob is just a bit heavier than you are. Even with the less weight he has on the tractor, when he puts it to work, it probably weighs more with him in the seat than the combination that you used.
Thanks for the comment VWJake :thThumbsUI second winning the tractor back. I also second Rob being a bit more counterweight than you are. No offense to anyone mentioned.
Hope for snow :fing32:
LOL... Knock him off the B100... would this have to do with the 3 ringA bet is a bet, but when it comes to husband/wife bets, they don't count like other bets do, so knock him off YOUR B100! :trink39:
Maybe, but Rob doesn't get on much anymore...after hearing this.he,ll feel so guilty . tractor should be back in your possession before long.don,t make the mistake of saying no. i lost the bet.this year we have had about ten inches of snow so far.way below normal to say the least.
:sidelaugh:sidelaugh:sidelaugh:sidelaugh:sidelaughWhy, I can't believe he took advantage of you like that! Rob is a very bad man!!!
Yikes, that sounds painful!!!*
Ring thru the nose--even if invisable to most.....:banghead3
glenn
Hmmmm, I wonder if this tactic would work... He does after all keepMerrie, give him the sad eyes with a tear in the corner of your eye! It will melt his heart and you'll be back on the WH in no time!
Or better yet... Instead of hooking up a plow people should considerMaybe someone can find a way to plow water. We have more than our fair share.
This is what I wear over my polyester shirt and snow pants. It's good down to about -20* F.WOW, I never thought about that, don't know why :dunno: He put
23X10.50-12 Super Lug's on it and filled them so they weigh 80 Lbs. each,
then he added those big thick weights on at 55.8 Lbs. (I think) then his
weight at 240 that comes out to roughly 511 Lbs. and all I had on it was:
165 on each rear wheel no loaded tires but me weighing in at about
140 Lbs. (completely bundled up: 3 pair of sock, 3 pair of sweat pants,
2 hoodies, 2 jackets, 1 coat, 1 hat, pair of boots, and 2 pair of gloves :thThumbsU)
that would equal roughly: 470 Lbs
for a difference of: about 41 Lbs.
