1 - 2 of 2 Posts
Anyone running an Onan on Avgas have any carb adjustment suggestions? Mine hunts a bit without "more" choke than I think it should need at WOT. Also, it really bogs if I move the throttle sharply from idle to WOT.
Do both of these symptoms point to the same adjustment needed? Like maybe I need to back the main screw out a bit?
Enjoy your weekend.:howdy:
I am running avgas in everything. I just gave a small tweak to the idle mixture.
You should not ever have to choke an Onan to keep it from hunting. Adjust or fix that carb.
1 - 2 of 2 Posts
