1 - 6 of 6 Posts
I have an older 420 that has become hard to start. Once I'm able to get it started and it warms up a little it runs ok, maybe a little weak, but ok. When I try starting it, it spits fuel out of the carb, like the accelerator pump is kicking in when it doesn't need to.
Maybe an intake valve sticking? How would I check or what symptoms would confirm? The fact that it clears up somewhat once it warms up kinda throws me.
Kish JD 318/420/430
Does this have the old style pulse pump or electric pump? When was the last time you did a decarbon and valve adjustment? These should be around 250 hours according to the Technical Manual.
This has a vacuum pump. I have never decarboned or adjusted the valves. It is almost certainly way over due. It doesn't look like the valve adjustment is all that difficult. What does the decarbon entail?
This is generally caused by a valve issue. First run a compression check, then pull the head and check the valves. I'll bet you lunch one of the valves is not closing on the compression stroke.
Three of my friends
It doesn’t have accelerator pump.
Kish JD 318/420/430
Unless the carb has been replaced, then there could be an accelerator pump on the carb, I know because I got one for my Onan a few years back.
1 - 6 of 6 Posts
