Onan Genset Question
605 Views 2 Replies 2 Participants Last post by  troyota71
Hi guys I some how got my hands on an Onan Emereald I genset. The ser# is B888010681 and I was wondering as to where I could find a manual for it. It needs some work but I'm sure it will run fine. Does anyone know if its a inch crankshaft or bigger as it might work on a Gravely ( The motor )
Thanks.
Troy.
1 - 3 of 3 Posts
Every generator I have fooled with that had the engine coupled dircet to the generator,had a tapered crankshaft PTO....some belt driven ones had the usual straight crankshafts though..yours probably will be a tapered version--its possible to buy or make an adapter to convert it to a straight PTO,but its probably not going to be cheap...a bearing supply place or machine shop are two places to try..you'll have to know what taper it has though,and getting the engine off the generator isn't always possible without damaging the generator..
I would just leave it as a generator ,if you can get it to run and put AC current out...
I will be leaving it as a generator. It was just a thought.Now I just need to get a manual for it. Thanks for your advise.
Troy.
1 - 3 of 3 Posts
