Short answer, yes, that sounds reasonable.
I've never set the timing on that engine, but overall it sounds right. You can eyeball check that you're at 19BTDC by looking at the piston position: it should be nearing TDC, maybe 1/4" below.
Not sure about 3/4 turn before the points close again. On a twin that seems a little long, as you're going to get another spark when you finish that turn. But really it's all about how they set up the ignition components: If the condensor has time to charge back up again, I don't see why you're not fine.
Actually, thinking a little more, all this stuff is automotive-derived. A V8 is sparking 4 times as frequently as our little twins at the same RPM. So I'm sure it's fine.
If one of the Onan experts sees this, I'm sure they can give a more definitive answer.
