My 446 runs rich. It has ever since I bought it. I know this because it belches out a bunch of gas when it starts, it stinks while it runs (to the point my wife makes me shower after working on it or running it) and it likes to backfire every so often.
Tonight I figured I would adjust that. I planned to use the standard method of turning the mixture screw in and then out until the engine changed sound and then setting the needle in the middle of those extremes.
I got out my trusty manual to determine which needle was which. Case of course doesn't call them the mixture screw and idle air screw like everyone else. They are instead the idle screw and the power screw. To me that means the mixture screw would be the power screw. It is located on the right side of the tractor. I turned and turned and turned until that screw bottomed out and the engine didn't change or bog out ever. It acted almost like that was the idle air screw rather than the mixture screw.
Is that not the mix screw? Is my needle bad enough that it isn't actually een regulating the flow of gas? Do I need to set this thing on the curb with a sign that says free?
