1 - 3 of 3 Posts
I have a 63 Ford 4000. Thinking the clutch has failed. PTO still works fine. But tractor will only slightly jump when you let out the clutch to move forward or backwards. I can slide it in and out of gear with it running, without depressing the clutch. Just slightly rocks the tractor. Mine has the 5 speed transmission. Does this sound like a clutch issue?
The pedal comes all the way up, tried adjusting clutch linkage was no change.
The clutch recently started grabbing at the very top.
1 - 3 of 3 Posts
