Greetings from the homestead here @ 7,500' elevation in the Rockies. I've been perusing the site for years and never really gave much thought to posting. Guess I'm finally getting around to it and I look forward to what could be ahead.
Appreciate all the folks that have posted info over the years, you made quite a difference for those of us who hadn't yet learned to use JD Parts Catalog. There's a ramp up period on their catalog, but once you learn how to navigate you're finally freed up/you did yourself a huge favor. i.e. There's a great deal of good info out on the web from folks with good intentions, but I learned the hard way one time that it's not all 100% accurate...YIKES!
I'm a novice who has owned, repaired, updated, bought & sold more JD 318s and 430 diesels than is helpful to bring to the memory of my devoted wife of 31 years. She's a great gal who turns the other way when the next one appears; secretly, I think she does a jig when each goes away!:dunno:
Finally got my original paint, 700 hour "keeper" '89 430 diesel dialed in with implements & such that I use at some point in our 4 seasons. Feeling mostly satisfied to the point the 430 is all I own at the moment. This sums up where she's at right now:
- HIGH intensity LED Headlights
- new high back seat
- spring assisted/tilt capable seat mount
- JD 60" deck
- JD Frame Extension
- JD PTO Extension
- JD Front weight bar
- JD Rear Weight Bar
- JD Weights:6x
- JD 4Way Quick Hitch
- JD Quick-Tach Plow
- JD Electric Clutch & 2K RPM PTO gear box with shroud
- JD 48" 3PT 2K RPM Tiller-2 hrs use when I got it last year
- JD Tow Behind 10 Cu. Ft Cart
- Old School (HD/HEAVYduty, 2x 1/2" steel frame members/not the new stuff) Brinly 3PT Single Bottom plow with Steel Drum Coulter
- Old School HD Brinly 3PT C-Tine Cultivator
- Old School HD Brinly 3PT 8-Disc Cultivator
- Carlisle HDAP tires
- Cast Iron Rear Wheel Weights, Chains
- the newest member of the "Green Family" arrived this weekend; a M047SBX Blower...complete with x-Series quick hitch and 4WD PTO shaft ( I obviously won't use these on the 430)
Welcome to MTF!! Thanks for the nice intro. Those 430 are really robust machines and it sounds like you have a well kept one too. Looking forward to seeing it!
I recommend all new members read The Getting Started Forum while they wait for the site to finish the validation process. During the validation time you may also wish to browse around the site and find the forum(s) which seem to best fit your area of interest.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
My Tractor Forum
