All:
First post here, so bear with the newbie.
I've got an old Garden Way "Horse" tiller, it looks as though there's quite a bit of discussion of those around here. It has the 6 hp Tecumseh engine, which broke the piston rod into several pieces, last time I ran it. The flying pieces inside the crankcase tool out the governor gear, for a good measure.
I've looked around a bit for parts, and the governor gear is pretty easy to find. The piston rod, though, is no longer available from standard sources (jackssmallengines, etc...).
It looks as though you can get aftermarket versions on ebay. Any experience with those? Do any of you know of any likely sources for an OEM piston rod?
Finally, any opinions on the 6 hp Tecumseh vs. the 7 hp Kohler that were standard on these tillers? Was the mounting bolt pattern the same for both engines? I was thinking that if fixing the tecumseh wasn't possible, then maybe I could run down one of the Kohler engines.
Thoughts?
Aaron
Thoughts?
Aaron
